Page 1 of 4
kytronic
Posted: Sun Dec 29, 2013 4:24 pm
by BIRDY3263
hi anybody fitted the kytronic unit ? we have just fitted one on a mates scoot and set timing to 24 but when the kytronic units fitted the timings at about 10 and moves up with revs seems to be going the wrong way any ideas?
Re: kytronic
Posted: Sun Dec 29, 2013 4:42 pm
by gp200ts1
it will drop back around 12 degrees for the 1st 1500/2000 revs then go back to near the static timing until 4000 rpm. it will then start to retard as the rpm increases. it all depends on what power curve you are using. if you look at the graphs on the kytronik site it shows how the curve plot out compared to rpm
Re: kytronic
Posted: Sun Dec 29, 2013 4:49 pm
by boris
Thats great thanks
Sent from my HTC Sensation Z710e using Tapatalk
Re: kytronic
Posted: Mon Dec 30, 2013 1:47 pm
by GP Kevo
Yes, they have very good instructions online and well selected ignition curves to suit most scooterists. There are even two of them, position 8 and position 9, that are for "street racer, Vespa or Lambretta, with ported cylinder kits and expansion exhuasts" to paraphrase them.
MB also has a very informative write up on them and ignition timing in general on their tech site.
Re: kytronic
Posted: Mon Dec 30, 2013 9:01 pm
by BIRDY3263
well fitted it to an rt195 with mb clubman went wth 23 static and setting 7 on the box he only did a few miles home so no real results yet' just threw us at idle when it went down to about 12 and then went up as apposed to my mtech that starts at 23 and then goes straight down
Re: kytronic
Posted: Tue Dec 31, 2013 10:47 am
by thebassmasta
my kytronik arrived this morning, ive been reading all the set ups and im still a little confused to what my setting should be.
MY SET UP
IMOLA 186 Ultimate (with wider yamaha reedblock and twin boost port)
JL4 Expansion
30mm Dellorto
Italian Li150 gearbox
Is mine Lambretta with cylinder kit and optimised pipe? or Street Racer lambretta with ported cylinder kit and proper expansion pipe?
Which curve would people recommend?
MRB tech site say set static timing to 25 degrees
Re: kytronic
Posted: Tue Dec 31, 2013 10:53 am
by GP Kevo
As far as I know, the Kytronik Smart Booster advances the timing from 0 - 3,000 or 4,000 rpm, then retards from there depending on the curve chosen.
Lots of info here: http://www.kytronik.com/sb
Kytronik is also working on a fully programmable Smart Booster with USB port for users to develop and upload their own curves from their PC.
Re: kytronic
Posted: Tue Dec 31, 2013 11:31 am
by ForemanBob
thebassmasta wrote:my kytronik arrived this morning, ive been reading all the set ups and im still a little confused to what my setting should be.
MY SET UP
JL4 Expansion
30mm Dellorto
The answer would be where you want your timing to finish up... 17deg?, 15 Deg? 13 Deg?
If the curve retards your timing from 25deg static by 8deg then you'll finish at 17.... but if you select the 12deg curve then you'll finish at 13...
but if you set your static at 29deg, you'll finish at 17deg with the 12 curve.
Re: kytronic
Posted: Tue Dec 31, 2013 2:11 pm
by thebassmasta
cambridge recommend a static timing of 15 deg on standard electronic
Re: kytronic
Posted: Tue Dec 31, 2013 3:31 pm
by ForemanBob
Well to achieve a final position of 15, set it to 23 or 27 depending on what series of curves you choose...
