Brake Pedal Splash Plate
Posted: Fri Dec 20, 2013 8:59 pm
by PeteB
The clamp-on splash plate for my Series 2 brake pedal has disappeared at the platers (more likely dissolved
). I can't find replacement ones advertised anywhere, nor the U-shaped clamp, so does anyone know who sells 'em, or even what the dimensions of the plate are so I can knock one up myself (should only take a few mins of shedcraft). Many thanks!
Re: Brake Pedal Splash Plate
Posted: Fri Dec 20, 2013 9:43 pm
by jazzyb
Scooter restorations
Posted: Fri Dec 20, 2013 10:13 pm
by PeteB
Cheers! Couldn't find it on their website, so will give them a call
Posted: Sat Dec 21, 2013 3:17 am
by Grumpy225
I should have one, will need to check. Can't imagine it would be more than a couple of pounds to ship across the pond.
Free, I'll never use it (haven't in the last 20 years and no reason to start now), just cover shipping.
Posted: Sat Dec 21, 2013 10:10 am
by PeteB
Many thanks Grumpy. If you find it, please PM me. I think it odd that everyone sells remade stand splashplates, but not the clamp-on brake pedal ones. No demand=no supply I guess!
Posted: Sat Dec 21, 2013 4:46 pm
by Monty
I have never seen a clamp on one. Mine was missing when I bought it with no sign of ever having one fitted. I would buy one if available as a lot of S**** comes up through the hole.
Posted: Sat Dec 21, 2013 5:07 pm
by PeteB
I have seen original-looking Series 1s and some S2s that don't have 'em Monty. Not being an anorak, it would worry me if it wasn't fitted, but I as you say they obviously started fitting the things for a reason
Posted: Sat Dec 21, 2013 5:48 pm
by gaz_powell
My S2 pedal had the plate missing (could see where it should have been by some weld marks - I just made one out of a piece of 1mm plate and tacked it on - made it the same size as a S3 one and its perfect but obviously its not original just functional
70mmx30mm and I just ran a grinder down the middle to form the slot
