Maghousing problem
Posted: Sun May 17, 2009 4:05 pm
by Dryballs
Hi guys,
I've been building an engine for my Series 1 but have encountered a little problem!
I've used a Series 3 Li125 case with a new indian mag housing
Crank is a 60mm evergreen crank
When I tighten the mag housing on it jams against the crank!
I'm sure the crank is pulled all the way through.
It only grabs when I tighten the flange down, so it must be only fractions of a mm out.
Is this a common problem?
I was thinking a slightly thicker mag flange gasket would fix the problem, or maybe try to dress down the mag flange face with some sand paper on a mirror?
Any other thoughts on this?
Cheers,
Christiaan
Re: Maghousing problem
Posted: Sun May 17, 2009 5:10 pm
by simon k
Hi there Dryballs.have you checked the big end clearance on the casing?had a similar problem with this crank had to grind out a channel.
or is the oil seal retaining plate sitting proud?
Simon
Posted: Sun May 17, 2009 5:45 pm
by Dryballs
simon k wrote:Hi there Dryballs.have you checked the big end clearance on the casing?had a similar problem with this crank had to grind out a channel.
Simon
Hi Simon,
I'll check it out... I also had the big end rub on a couple of places when I first put the crank in. I routed a channel in the casing for this with my die grinder
I might take the crank out and check the seal plate, but I would have thought it would catch on the crank rather than just push the crank out.
mmmm something more to ponder!
Chur,
db
Posted: Sun May 17, 2009 5:48 pm
by goldeneye
check your oil seal retaining plate to see if it"s warped, aluminium ones are crap. have you lubed everything on assembly? somtimes a coating of clean two stroke makes everything ok. i never assemble an engine "dry". you could try two mag housing gaskets, but your better off trying to fettle the root cause of the problem. hope this helps. goldeneye.
Posted: Sun May 17, 2009 9:00 pm
by dsc scotty
Check crank webs are fully pressed together, look at crank pin is it flush with webs? also crank may be out of true?
Posted: Mon May 18, 2009 8:11 am
by Dryballs
Thanks for your thoughts guys,
I might pull the crank out and check it over.
I'm not too keen on using 2 mag gaskets, its kinda like using 2 head gaskets! although I guess I could silicon them together?
I'll let you know what the crank looks like.
Cheers,
Christiaan
Posted: Mon May 18, 2009 2:54 pm
by Knowledge
Two gaskets is not as big a crime as two head gaskets. It is an easy thing to try, without stripping the engine.
