Where To Put SIP Speedo Box
Posted: Mon Dec 16, 2013 10:40 pm
by soulsurfer
It's always tight under the headset what with extra bits & bobs like hydraulic hose extra earths and wiring for gauges etc., the SIP speedo's bulky wiring doesn't help, but where do you put the rather space consuming black box? particularly on a Spanish Series 2, can it go under the horncasting, or elsewhere? Any pics will help.
Thanks.
Re: Where To Put SIP Speedo Box
Posted: Tue Dec 17, 2013 2:30 am
by Minority
Like you I felt it was too crowded in the headset so I decided to fit it under the horncasting (series 3).
As I fitted it at the bottom I needed to extend the cable, an easy job with some multicore cable and shrinkrap from the electronics store.
Posted: Tue Dec 17, 2013 11:47 am
by soullad
I used the extension provided and popped it near the usual CDI / Reg position. I felt that I've got to remove this panel anyway to check wires etc should anything go amiss?
