Non driveside bearing
Posted: Fri Dec 13, 2013 8:15 pm
by belly
What are the pros and cons of using petroil lubrication on non driveside bearing. I know series 1's and early series 2's ran this and I see Super Monza is same
Re: Non driveside bearing
Posted: Fri Dec 13, 2013 8:20 pm
by Muppet
constant cool feed of oil/petrol i gess
Posted: Fri Dec 13, 2013 8:25 pm
by sean brady scooters
and slightly reduced frictional losses maybe
Posted: Fri Dec 13, 2013 8:28 pm
by belly
See Mito Racing does a conversion kit to run single oil seal but I would think the mag housing would have to be machined, presumably with a slot running from cut out by transfer. Would it be worth doing on a TS1?
Posted: Fri Dec 13, 2013 8:31 pm
by Muppet
mite be reduced friction; gess 1 seal has less friction than 2 seals an bearings run higher rpm in oil than they can in grease cus they run cooler
