T5 cylinder
Posted: Fri Nov 29, 2013 9:46 am
by Chris H
I've got an old T5 cylinder that has been seized and now has damaged plating. Can it be rebored, replated, and a bigger piston used or just replated and use a standard piston.
Re: T5 cylinder
Posted: Fri Nov 29, 2013 11:07 am
by roadrunnerian
Hi m8 you can have them replated or see if there is a 2nd hand one for sale,or buy a kit polini,malossi or try martin at chiselspeed he is very helpfull hope you get sorted m8
Re: T5 cylinder
Posted: Fri Nov 29, 2013 5:28 pm
by gaz_powell
you could bore it out, replate it or steel line it and use a suzuki TS185 piston
Re: T5 cylinder
Posted: Sun Dec 01, 2013 6:07 pm
by Chris H
gaz_powell wrote:you could bore it out, replate it or steel line it and use a suzuki TS185 piston
This sounds just the job, if I remember correctly Mark Broadhurst used to offer something similar in the late 80's. The next question is would it work with a box exhaust and up jetted carb?
Re: T5 cylinder
Posted: Sun Dec 01, 2013 9:41 pm
by gaz_powell
MB still does them equally chiselspeed or JB Tuning would do it.
or as already said take a polini barrel and bore it again use a TS185 piston
good luck
Re: T5 cylinder
Posted: Mon Dec 02, 2013 3:46 pm
by cezeta
box pipe and standard carb works perfectly
Re: T5 cylinder
Posted: Mon Dec 02, 2013 9:05 pm
by gaz_powell
you will need to rework the head if you use a ts185 piston
Re: T5 cylinder
Posted: Tue Dec 03, 2013 7:18 pm
by Chris H
Thanks for all the advice lads really appreciate it. I've decided to go for it and will let you know how I get on.
Re: T5 cylinder
Posted: Tue Dec 03, 2013 8:08 pm
by ducksta
i have the suzuki conversion done by chislespeed top job
