GP headset bush replacement question
Posted: Fri Nov 29, 2013 12:47 am
by jedan71
Hi
Apologises at first for my idiot question, i received a GP headset bush kit the other day and am now ready to fit it, but i found 4 white round shaped bushes in the kit, i can see that two have raised groove that slide into the handle and then the rod and roll pin will secure it, then i find i have 2 other hat looking bushes, having a mind melt and cant think where they go, they slightly larger diameter than the tube, hole in middle and have a slight lip to give like a top hat look on them. :oops: these must be different from the standard set up and not in Stickeys book either
Sorry if my description is not the best, will take a photo if need be.
Also can i fit the gear change without the vibration ring to it?
Re: GP headset bush replacement question
Posted: Fri Nov 29, 2013 7:02 pm
by wack 63
The top hat bushes go into the steel ends of the headset and normally need tapping in although some are machined oversize so need fettleing.
Posted: Mon Dec 02, 2013 1:24 am
by jedan71
Thanks for that, my dremel and i had fun, fettling the plastic down.
