Spanish series 2 frame weakness.
Posted: Fri Nov 22, 2013 9:19 pm
by Ihateyoubutler
Am I right in thinking the Spanish series 2 has a weak spot regarding the part of the frame where the engine mounting bolt goes through the frame? Is this area prone to failure/cracking? Might put a tuned motor in, so do I need to strengthen this area up?
Thanks.
Re: Spanish series 2 frame weakness.
Posted: Fri Nov 22, 2013 9:50 pm
by Doom Patrol
You sure about that? Don't think I've heard of one giving way there. Or is it because the later S3 did indeed have strengthened brackets in that area?
Posted: Fri Nov 22, 2013 9:57 pm
by Donnie
first Ive heard of it for sure and Ive been running mine hard for about 8 years!
Posted: Fri Nov 22, 2013 11:52 pm
by tony81
Early series 2 had a weak spot on the frame tube not sure about Spanish frame
Posted: Sat Nov 23, 2013 12:51 am
by Minority
Posted: Sat Nov 23, 2013 7:48 am
by soulsurfer
Posted: Sat Nov 23, 2013 8:24 am
by whonatic
Ihateyoubutler wrote:Am I right in thinking the Spanish series 2 has a weak spot regarding the part of the frame where the engine mounting bolt goes through the frame? Is this area prone to failure/cracking? Might put a tuned motor in, so do I need to strengthen this area up?
Thanks.
Can't do any harm Stu, I've seen 3 Spanish series 2's crack the welding on the kickstart side.
Posted: Sat Nov 23, 2013 11:42 am
by Ihateyoubutler
Thanks for all the replies, much appreciated.
