vespa 90 question
Posted: Thu Nov 14, 2013 5:21 pm
by handofdave
right here goes, not very familiar with smallframe engines but have one in bits now,i need to know whether between the flywheel side bearing and the casing is there a spacer?it shows one in the manual but cant seem to find one anywhere or is it not needed/superceded?,i am using a one piece bearing
any feedback appreciated
dave
Re: vespa 90 question
Posted: Thu Nov 14, 2013 7:41 pm
by wack 63
Can I suggest you join the Smallframe forum, some experts on there. I've never come across a spacer between the casing and the bearing as standard.
Posted: Sun Nov 17, 2013 5:12 pm
by santacama
Me neither.
Posted: Sun Nov 17, 2013 7:24 pm
by hobospeed
I'm pretty sure the original "small door" small frames used a spacer. These are the engines with smaller cylinder spigots and two pronged sliding dogs in the gearbox. Here is a parts book that shows the spacer you are talking about:
I'm pretty sure they did away with this spacer when the original primavera came out.
Tim
Posted: Sun Nov 17, 2013 7:43 pm
by wack 63
Interesting, I've never worked on one of the real early motors, nice bit of info.
