Headset Control Roll Pins Help Needed
Posted: Fri Nov 08, 2013 9:27 pm
I'm in the process of restoring a GP and have come to reassembling the headset controls. I have got all new control rods, roll pins and nylon bushes bought from a reputable supplier who deals in mainly SIL parts, so everything should fit.
My problem is getting the roll pins in. I have started by trying to fit a shaft end bush to the control rod. The roll pin goes through the bush with a few light taps of a hammer but is so tight it won't go through the rod. At least I don't think it would without a great deal more force than I am prepared to give it. Even if I got the shaft end bushes fitted I don't see how the throttle and gear wheel can be fitted without risking damage to at the least my new paint or at the worst the headset itself because these have to be done in situ. Stickys manual does not give a lot of advice on fitting these pins except to say they are press in. Do they need to be fitted with a special tool? Any advice on how to get the control rods assembled without any damage greatfully received.
Phil
Phil
