Page 1 of 3
H4 headlight conversion
Posted: Thu Nov 07, 2013 12:37 pm
by vRSG60
Can someone point me in the direction of the guide on how to convert a GP headlight to an H4 halogen bulb.
Re: H4 headlight conversion
Posted: Thu Nov 07, 2013 1:36 pm
by Toddy
Posted: Thu Nov 07, 2013 2:14 pm
by vRSG60
Thanks.
Posted: Thu Nov 07, 2013 6:27 pm
by dave wheeler
is this process any different with a 63 TV carrello set up?
regards
dave
Posted: Thu Nov 07, 2013 10:13 pm
by purple_pill67
i cut up a repro s3 holder and added glued in the h4 block.
not a perfect job and would take my time abit more next time but was in a rush last time.
h4 bulb from the pound shop but osram nightbreaker 55w are the best to get so im told.
Posted: Fri Nov 08, 2013 12:00 am
by coaster
I've posted this before but h ere's some pics of mine on an LiS, it's been tidied up a bit since but should give you an idea. The benefit of the H4 conversion over the Beadspeed type lamp is that a 55/60 watt lamp is available and as mentioned, the Osram Nightbreaker is brighter still.
Posted: Fri Nov 08, 2013 1:24 pm
by vRSG60
I have countless H4 bulbs in my "spare bulb" box. "Uprated" ones from Aldi, "HID" look ones from various scources. I've ordered a spare GP bulb holder and I'll get a connector block at the weekend and give it a go. It looks as though the metal shield with the prongs will have to go to fit in a GP holder.
Posted: Fri Nov 08, 2013 11:48 pm
by corrado
With the GP holder it's very simple. Just remove the existing prongs to the bulb and file the existing hole slightly bigger so the H4 bulb is a nice tight fit. The connector just plugs into the other side, the bulb holds it tight. The 3 prongs on the outside of the bulb usually just tear off with pliers. Red and Blue wires as normal and splice another wire into the Yellow and connect to earth on the block. Blocks are about £2 then get a H4 bulb set from a pound shop to try but they're 55/60 watt so rear LED bulb is a must. Quality H4 in 35 w are available but not cheap.
Posted: Fri Nov 08, 2013 11:55 pm
by Weston-scooterist
I've had a scootrs halogen lamp in my lis for over a year, brighter than a px headlamp, no modification, just slotted in, is the gp lamp holder different or am I missing something
Posted: Sat Nov 09, 2013 12:03 am
by corrado
Probably not, I was just taken in by the Sparkright blurb at the time but the £3 build cost is cheaper than most aftermarket halogen bulbs.
