Page 1 of 2
Speedo not working
Posted: Sun Nov 03, 2013 8:06 pm
by jbg584
Hi
had this speedo fitted to my S in Law's LML deluxe but she wanted it returned it to an original speedo fitted one and replaced its inner and outer cable however it doesn't work is there a special way the cable goes at the drive end.
Ray
Re: Speedo not working
Posted: Sun Nov 03, 2013 8:13 pm
by rosscla
With the cable in the hub and the plate bolted down, does it turn at the headset end when you spin the wheel?
Posted: Mon Nov 04, 2013 3:03 pm
by markpryke
hi lmls are none for chewing speedo worms
Posted: Mon Nov 04, 2013 3:45 pm
by ducksta
make sure when locating the cable/worm you spin the wheel the the other way or the teeth will just cut up
Posted: Mon Nov 04, 2013 4:34 pm
by jbg584
Hi
Speedo worked with the other speedo and cable in.What do you mean spin the wheel the other way what does that do?
Ray
Posted: Mon Nov 04, 2013 5:32 pm
by ducksta
when refitting worm or cable the worm can rise up so not engaging with wheel on hub by spinning wheel the other way it sinks down correctly to engage otherwise it can chew worm up streight away
Posted: Mon Nov 04, 2013 7:50 pm
by wink
when you say "spinning wheel the other way " I take it you mean turning the the wheel in reverse (backwards, towards the bike)?
Posted: Mon Nov 04, 2013 9:13 pm
by jbg584
Hi
Thanks will try that hope I havn't done damage already as the scoot has been ridden since but not far.
Ray
Posted: Tue Nov 05, 2013 5:31 pm
by markpryke
it only few pound for a new worm if u have damged it it the grey worm you need for a lml
Posted: Tue Nov 05, 2013 8:07 pm
by goldeneye
that's not an LML speedo.
