Motorcycle petrol cap?
Posted: Sat Nov 02, 2013 7:31 pm
by Birdie
Want to fit a motor cycle petrol cap to a cut down, using stainless scooter products 17 litre tank. Sure someone has advised using a Yamaha one.
Is there a particular model I need to get - about seventeen to choose from on eBay
Thanks
Re: Motorcycle petrol Tao?
Posted: Sun Nov 03, 2013 11:54 am
by 10 inch Terror
Are you after the Aero type flip up cap, or a screw in type?
Posted: Sun Nov 03, 2013 6:58 pm
by Birdie
One with a flip opening like this - have seen them fitted but is it an easy job? Will be taking the frame to do a bit of welding and wanted to get this mod done at same time:
Hope this works!
http://www.ebay.co.uk/itm/Yamaha-YZF-75 ... 5aef09d269
Thanks for help
Keith
Re: Motorcycle petrol cap?
Posted: Sun Nov 03, 2013 7:19 pm
by RICSPEED
its not an easy job .. I have done it on my gp but what you have to remember is that the tank is rubber mounted and the loop isn't so the aero cap effectively becomes a fancy looking flap with the standard cap underneath
this one however has the cap attached to the tank (or so it would appear) and the nessasary clearance
Posted: Sun Nov 03, 2013 11:13 pm
by 10 inch Terror
I've fitted one to my scooter but it's not an easy process. The biggest problem I had was the difference in sizes between the outlet of the cap and the size of the lambretta tank opening. I had to get a special step rubber made by a company in Hong Kong via eBay. Also you need to make an adaptor plate to screw the cap to which then needs welding to the frame loop above the petrol tank which if you can weld and have access to a welder is no biggy. Also once the aero cap is fitted it leaves very little room between it and the fuel tank meaning the cap needs careful cutting down. I have a Diablo long range in mine and once fitted I had a hell of a job connecting the rubber between the cap and tank and doing up the jubilee clips but it can be done with a bit of thought and effort. If you like I can take a few photos and post them up for you. Cheers and good luck Pete.
Posted: Mon Nov 04, 2013 5:44 pm
by RICSPEED
10 inch Terror wrote: I had a hell of a job connecting the rubber between the cap and tank and doing up the jubilee clips
for that reason I chose to not have mine connected in any way with standard cap underneath
Posted: Mon Nov 04, 2013 7:08 pm
by 10 inch Terror
This is more or less the exact same way I fitted mine. How do you get your hand in to unscrew the cap off the tank? I did think of leaving the rubber connector off but I couldn't get my hands in to unscrew the cap.
Posted: Mon Nov 04, 2013 7:35 pm
by RICSPEED
I have long fingers :lol:
Posted: Mon Nov 04, 2013 7:52 pm
by Birdie
Hi thank you for explaining how to do this and sharing the photos. Looks like retaining the original cap underneath is the easiest option, however I have short fingers :lol:
