6v to 12v lighting
Posted: Wed Oct 30, 2013 8:43 am
by thackers
Hi guys, i'm wondering if it's possible to convert the lighting on a 6v points system to 12v using a BGM regulator? I understand it can be done with a different type of reg' but i'm wondering if the BGM one is 12v only. Thank you. ;)
Re: 6v to 12v lighting
Posted: Wed Oct 30, 2013 4:49 pm
by Grumpy225
You can pretty much use any 12v regulator. Assuming you are converting a standard 6 pole 6v AC stator, just common all of your lighting wires to one port on the 12v reg and feed the loom off the other port.
Now it's not a very clean way to do this but it will work. There's lots of people who have done this and it's even listed on some shop sites as a how to.
Posted: Wed Oct 30, 2013 6:32 pm
by firekdp
Grumpy225 wrote:You can pretty much use any 12v regulator. Assuming you are converting a standard 6 pole 6v AC stator
Yeah, a 12v reg is a 12v reg, and should be possible with any 6v stator.
Posted: Thu Oct 31, 2013 11:01 am
by thackers
Thanks fellas that's all I needed to know ;)
