I normally use grinder and wire brush, but the area is to small, even for a drill and wire brush. I normally use nitromorse but working inside, I don't want to go to the sand blasters are there any other methods/products.
cheers
Removing Paint
- CutdownSpence
- Main scooter: 1966 Silver Special
Needle gun
One Of England's Finest Salad Dodger's.
Nitromors and man up or invest in a clothes peg
Nitromorse fine, if there arer not too many nooks and crannies...eg underside of Vespa headset where it can get lodged in the corners.
Is there something in this: http://www.aircooledtech.com/tools-on-t ... a_blaster/ method, maybe with a different media eg fine sand?
- carlos fandango
Ive just had some panels done here, not the cheapest but as i didnt want a sandblasted finish on the steel, they look great.
http://www.surfaceprocessing.co.uk/index.html
GLscoot
- Main scooter: Vespa GS150
So that will be a hot East European with a gun and a sore tonguemick1 wrote:Heat gun....."or pay some one to lick it off".....some East European would probably do it for less than the minimum wage
