Snetterton Seat blocks petrol flap
Posted: Fri May 15, 2009 5:14 pm
by TheSeeker
Hi Folks
I've got a Snetterton on my GP cutdown which I thought I might fit to my full body Li as the GP is in bits for a rebuild.
Silly question but do I need to remove to the petrol flap? It doesn't seem to open with the seat in place.
Best regards
Ben
Re: Snetterton Seat blocks petrol flap
Posted: Fri May 15, 2009 8:24 pm
by fred
yes,remove flap
Posted: Fri May 15, 2009 8:29 pm
by storkfoot
I've had to dremmel the metal a bit by the air scoop a bit before now as it was overlapping the petrol flap. Snets, generally, are not hi-tech seats, so they may take a bit of work. That said, both the ones I've run in the past have been with an opening and closing petrol flap.
Are you the Belgian lad with the cutdown, GP headset, white Vega leggies?
Posted: Fri May 15, 2009 8:39 pm
by TheSeeker
storkfoot wrote:I've had to dremmel the metal a bit by the air scoop a bit before now as it was overlapping the petrol flap. Snets, generally, are not hi-tech seats, so they may take a bit of work. That said, both the ones I've run in the past have been with an opening and closing petrol flap.
Thanks for the advice, I thought it looked a bit too simple to just bolt it on.
Yes that sounds like me although I'm originally from Porthcawl in South Wales. Been out here in Belgium for ten years now, you know how it goes, travel out for one job and 18 months later you have a family and it doesn't seem worth going home.
The GP is in boxes being stripped while I try to find a decent paint sprayer over here. I might just invest in a gun and compressor and do it myself.
I'll be in Lincoln in June if you'd like to meet up. Maybe I should get a t-shirt with my name on like Keith Moon
Ben
Posted: Fri May 15, 2009 8:51 pm
by Andy Pickering
Going back to the 80s they flap never shuts correct my advice...lift the flap
..fit the seat then push as close as you can..it wont shut correct BUT you wont get rain water inside the scoot...nice scoot by the way...
Posted: Fri May 15, 2009 9:20 pm
by storkfoot
Brussels, or Porthcawl, must be a tight call that one, mate :biggrin: I was on the verge of finalising plans for a cutdown/racer project of mine when I saw this pic several months back. I changed my plans as I just think the GP headset goes so well with the Vega leggies.
I'll happily pinch all your best ideas at Lincoln
I'll PM you nearer the time. Cheers.
Paul
Posted: Fri May 15, 2009 10:01 pm
by corrado
TheSeeker wrote: Maybe I should get a t-shirt with my name on like Keith Moon
Ben
Err, but everyone would call you Keith and not Ben.
