Reprofile SIL cylinder head
Posted: Tue Oct 22, 2013 11:27 am
by pasner
Im planning a rebore for my Jet 200 barrel to 70mm using Avanti piston, clean up and match. I just bought an Indian 200 cylinder head from SR. I will need to reprofile it to suit the dome of 70mm. I read somewhere that lowering the compression helps to suit unleaded petrol.
A good pal has all the machinery to do this labour but he is not in to scooters. How can I expain what is needed and how to do these all? bit lost with engeenering details.
Re: Reprofile SIL cylinder head
Posted: Tue Oct 22, 2013 3:05 pm
by shocky
Its no realhelp now buti woud have got one from rays ped ther about 35 quid
Posted: Tue Oct 22, 2013 6:07 pm
by camel
ive reprofiled a sil head for my muggello 225,it also has an avanti piston
you need to tel him as you have mentioned the profile needs to be the same as your piston crown.i carefully cut a template out of thin cardboard 70mm width and with the profile of your piston crown and machine to suite...the gasket face to the lowest point of the combustion chamber needs to be 0.860".ish
i tap the stud holes 10mm so it can be bolted to a jig which goes in the lathe chuck.
if its a one off it may be easier to buy one but if you have the gear and the time definatly have a go.
Posted: Tue Oct 22, 2013 9:03 pm
by rosscla
+1 on just buying one from AF, that's what I've used on my rapido / avanti piston
Posted: Tue Oct 22, 2013 9:13 pm
by lambro
shocky wrote:Its no realhelp now buti woud have got one from rays ped ther about 35 quid
"Rays ped"
Is that like what the kids call their mopeds
Posted: Wed Oct 23, 2013 12:31 pm
by pasner
thanks to all. I have surfed the net and found some cylinder head jig drawings that will suit my project.
http://www.granturismo.pwp.blueyonder.co.uk/tooling.htm
But unfortunately only one of the drawings is avaliable at the moment. Does someone got these CAD drawings? I will PM Rich and invite to join this thread.
