SIP Cosa Clutch - Is this correct?
GLscoot
Main scooter: Vespa GS150
The gear cogs for the COSA 2 clutch are available with 20, 21, 22 and 23 teeth. The cogs with 20 or 22 teeth fit into 125-150cc motors and the 21 or 23 toothed cogs into the 200cc motors without having to also replace the primary driven gear cog. If, on the other hand, another primary gear cog or the DRT clutch gear cogs are used, more transmission ratios are possible. All VESPA large frame models since the VNA/VNB range up till 1994 can be fitted with the COSA II clutch. With these 125-150cc models the existing clutch cover must either be modified due to the largest size of the COSA 2 clutch conversion, or replaced with the clutch cover from the 200cc motor with a suitable pressure plate.
This was copied from the sip website.
Jack221
Main scooter: PX221
I have no reason to doubt it. Here is the next paragraph too;
he primary driven gear cog in the 200cc motor with 65 teeth can be combined with 21 or 22 toothed cogs, along with the original item with 23 teeth. The most popular clutch gear conversion cog is the version with 22 teeth, so enabling an improved acceleration through the gears, without expensive tuning measures, especially between 3rd and 4th gears.
