ts1 225- jetting details for a 30mm phbh dellorto
db67
hi just running in my ts1 225 & my set up is a jl 3 exhaust & 30mm phbh dellorto with a ram air filter,just wanted to know if i'm fairly close with my jetting. main 135. pilot 55. atom. av 266. needle x7 2nd clip from top & a 50 slide. thanks for any info. db
carlos fandango
Don`t know why you haven`t had a reply to this?
I can give you the jetting for a rb20 should be in about the right area for you.
MJ 138
X7 T2
AV266
    Users browsing this forum: No registered users and 50 guests
