SX Li Crank Big End Gap
Posted: Thu Oct 10, 2013 8:34 pm
by Lamaddict
The crank came out of a running engine. I've always replaced TV SX cranks but this is a different situation, long story. I'm shocked by the gap between the con rod and the crank web.
Re: SX Li Crank Big End Gap
Posted: Thu Oct 10, 2013 10:18 pm
by rosscla
The side float should be in the 1.1 - 1.275 mm region, max 1.5 mm
I think the rod should be centralised by the fitting of piston shims? Were any fitted when you took it apart?
Posted: Fri Oct 11, 2013 2:42 am
by Lamaddict
rosscla wrote:The side float should be in the 1.1 - 1.275 mm region, max 1.5 mm
It wasn't me that took it apart but the new piston will not have any shims but I guess the new piston it's slightly wider so it should centralize.
Posted: Fri Oct 11, 2013 10:32 pm
by Lamaddict
I've just married up the piston to the small end and there's room for shims so I'll get some in.
