Engine Stalling when throttle turned
Posted: Wed Oct 09, 2013 2:25 pm
Hello,
please help me before I burn the little devil scoot!
I have a Vespa P150X with:
Polini 177 kit.
Dell'Orto SI 24/24 E carb.
Jets (Slow Running 55/160) (Air Corr 160/mixer BE3/Main 110) (Starter 60)
NGK8 plug.
Tuned Pipe
The fault: The scoot starts 1st/2nd kick with choke on and will warm up until I can then turn choke off but if at anytime I pull the throttle the engine stalls(sounds more like sucking loads of air) I cannot get scoot to higher revs without it stalling. The scoot ran ok one day and then the next it had this fault?
Things I've done: Checked timing/adjusted mixer screw to all settings/cleaned carb at least 3 times inc jets/changed plug/change HT lead/changed. plug cap.
I will burn the little fecker soon!
Anthony
Polini 177 kit.
NGK8 plug.
Tuned Pipe
Anthony
