AF flywheel
Posted: Fri Oct 04, 2013 8:01 pm
Hi all,
I need a new flywheel,currently using indian stator and long fin flywheel,my mate has lent me a lightened AF flywheel which when fitted,even with a smaller flywheel cowl still has about a 15mm gap between fins and cowl! will this cause cooling issues?
I've also noticed that the timimg mark and trigger magnets are in a different place which will mean making new timing marks and i guess elongating the holes on the stator to be able to achieve correct timing,is this normal?
Many thanks
Many thanks
