BGM Racetour kit
lammydave
OK, got one of the above with the 4 holes on the exhaust port
What are my options exhaust-wise
is it just the bgm?
speedy
If you mean because it has the 4 stud holes then no,you can use anything.The mb/bgm pipes have been made with the four stud fixing,quite clever if you can get to them easily.But they will take all standard stub/flange pipes that are available.Cheers,Speedy.
I'd go with the same set up that you've used successfully on the Muggy 185s David. Bearing in mind, jetting wise, that it's 195 cc over 185 cc. Try the Ancillotti first. Though I suspect the BGM may give it a few more revs.
As Speedy says ... also note that even though the MB / BGM exhaust stub has 4 holes it'll still work on the conventional 2 hole cylinders.
Timbo
If you go for the bgm bare in mind you have to paint it and get a copper gasket.
Minority
Main scooter: Li230 S3
    Users browsing this forum: Ahrefs [Bot] and 3 guests
