wires everywhere
Posted: Tue Oct 01, 2013 9:12 pm
by jbg584
Hi
Has anyone got a wiring diagram or knows how to wire up this speedo Its on my sister in laws LML 125cc 2004 she just bought, took the headset of to try and see why speedo light wasn't working what a mess.Loose wies everywhere managed to get head and dip working cant get fuel or indicators to light or fuel gauge to read.
HELP Ray
Re: wires everywhere
Posted: Wed Oct 02, 2013 7:26 am
by mick1
Haynes manual might have something.........
Posted: Wed Oct 02, 2013 8:21 am
by ducksta
dont panic when you look at the crimps at the end of the wires they should only fit certain terminals the black is earth as for the fuel gauge etc look at the metal strip on the speedo make sure its clean and the large terminal clips on flush post a pic and we should talk you through it
Posted: Thu Oct 03, 2013 5:39 pm
by jbg584
Hi am going to take couple of pics, managed to get lights working cant get single indicator on speedo to flash with each side or where to connect fuel light.
Ray
Posted: Thu Oct 03, 2013 6:30 pm
by wack 63
Not sure on a LML but Vespas warning indicator light flashes via a grey wire from the indicator switch. One of the main problems with any of the warning lights is corrosion on the bulb holder contacts and the printed circuit board. Check the holders with a battery to rule them out and use a multi- meter to trace the individual circuits to each warning light.
Posted: Thu Oct 03, 2013 6:53 pm
by jbg584
Hi
Cheers will try that
Posted: Sun Oct 06, 2013 8:55 am
by markpryke
lml don't have a printed circuit board they just have a rubber bulb holder that push in
