B7 in avanti
Posted: Sun Sep 29, 2013 8:21 pm
by sydduckett
Have been told wise to use a B7 in an avanti head as they run so cool. anyone doing this?
ta
Sef
Re: B7 in avanti
Posted: Sun Sep 29, 2013 8:33 pm
by Donnie
Im not familiar with the avanti I have to say, but I do find it hard to believe a b7 is recommended
Re: B7 in avanti
Posted: Sun Sep 29, 2013 8:42 pm
by Donnie
Just did a google and found
http://supertune.co/downloads/avanti_fi ... ctions.pdf
Have you not seen the instructions or did you not fit the kit? It clearly says
" Use an NGK B8ES spark plug or equivalent whilst running in then maybe changed if necessary to a B9ES"
Re: B7 in avanti
Posted: Sun Sep 29, 2013 9:20 pm
by Adam_Winstone
I guess that might suit the bike nicely around town if you are running in, however, I'd swap back to the 8 if you know that you are going to up the speed on some faster roads.
Re: B7 in avanti
Posted: Sun Sep 29, 2013 11:20 pm
by OAP
I have to say that I have used a B7ES around town and on a blast and it is fine, Also a customer running one of the heads on a TS1 found that it was better to use a B7Es. But like everything you must keep an eye on it! In cold weather I would be using a 7
Re: B7 in avanti
Posted: Tue Oct 01, 2013 6:40 pm
by sydduckett
OAP wrote:I have to say that I have used a B7ES around town and on a blast and it is fine, Also a customer running one of the heads on a TS1 found that it was better to use a B7Es. But like everything you must keep an eye on it! In cold weather I would be using a 7
from the horses mouth...
I'm guessing your happy man if the heads doing what it's intended for....
Re: B7 in avanti
Posted: Tue Oct 01, 2013 7:03 pm
by Andy Pickering
Mine hated the b9, and was fussy round town with b8, its sharp as a tack on the work run with the b7 and swap up to b8 for rallies.
Re: B7 in avanti
Posted: Tue Oct 01, 2013 7:38 pm
by coaster
Andy Pickering wrote:Mine hated the b9
Mine too, tried one on the C2C but it was really oily.
Re: B7 in avanti
Posted: Tue Oct 01, 2013 7:51 pm
by Andy Pickering
coaster wrote:Andy Pickering wrote:Mine hated the b9
Ditto, looked like it had been dipped in oil, I took it that it was running to cool
and couldnt burn it off, the b7 and b8 gives a lovely plug under the respected riding ie 7 town 8 rallies.
