Revs Hanging
Posted: Sun Sep 22, 2013 10:36 am
Ok i thought i saw a post similar to this on put cant seem to find it so apologies if this is a repeat post .....i am running a honda 205 on 25MM Delly carb with k+n type filter on carb rubber and 42 Af Clubman jetting is currently 50 idle 40 slide d26 needle AQ264 atomiser 102main and 50 idle 250 needle valve all seals good ,top end rebuilt and new crank and bearing recently
now it hangs a bit coming down the rev(annoyingly) especially when coming stopping at traffic light or stopping in general i.e its reving slightly high then settlies down to tick over ....So i am thinking fit i larger idle jet a 53 is all i have ,would this be a quick fix or are there more to it ...Ta Bill
