Page 1 of 2
wish i could give up smoking
Posted: Sat Sep 21, 2013 11:43 pm
by camel
why do some motors smoke like hell
mine does to the annoyance of people who ride with me,i run silkolene pro 2 pre mix and 33/1 ratio.
im definatly not burning gearbox oil.
its worse after a fuel up,ive tried putting the oil in first before the petrol to help mixing but its no better.
luckily it dosnt foul plugs...does anyone mix their oil at a weaker ratio?
motor is a reed valved muggello 225
30phbh,and a ads3 pipe
Re: wish i could give up smoking
Posted: Sun Sep 22, 2013 3:05 am
by Boothy_the_makem
Are you pissed ?
Lol
Posted: Sun Sep 22, 2013 7:20 am
by drunkmunkey6969
If engine is tight and seals are ok, at 3% mix you shouldn't have major smoke issues....... Unless you are running rich jetting? That would cause it to smoke if it is over-rich.
Posted: Sun Sep 22, 2013 9:31 am
by camel
not as pissed as your flywheel mr booth
Yes Dan its a possibility,been thinking of down jetting for some time,it was set up "safe" on a dyno when initially built,my fuel consumption isnt the best considering the reed valve is fitted.Averaging 8 miles per litre
Posted: Sun Sep 22, 2013 9:42 am
by Pepot
Couldn´t it be a simptom of a problem with the chain side oil seal? I'd have a look to the gear box oil level.
Edited:
Sorry,I'have read again your post and saw that you have allready done this.
Posted: Sun Sep 22, 2013 5:39 pm
by Boothy_the_makem
camel wrote:not as pissed as your flywheel mr booth
Lol. I like smokey scooters
Peeps should put some in the exhaust like the old days lol
And its no where near as annoying as the feckers with all the mirrors going to rhyl in the sun yesterday.
I thought the feckin paparazzi were after me
Anyway it looked fine when you rode in yesterday . Maybe you were comparing it to your mates LN you rode with hahaha
Posted: Sun Sep 22, 2013 6:18 pm
by wack 63
Personally I think silkoline is too thick and expensive to mix on a road bike, its not too bad if mixed and shaken in a can but it soon " drops out" the petrol and settles in the bottom of the tank and float bowl, put a mix in a milk bottle and stand for a few days. Pro 2 is more a race oil that would be discarded after a meeting, so I recommend something like Rock Oil Synthesis injector mix at 3% and the bike will hardly smoke whilst riding.
Posted: Sun Sep 22, 2013 6:39 pm
by Boothy_the_makem
wack 63 wrote:Personally I think silkoline is too thick and expensive to mix on a road bike, its not too bad if mixed and shaken in a can but it soon " drops out" the petrol and settles in the bottom of the tank and float bowl, put a mix in a milk bottle and stand for a few days. Pro 2 is more a race oil that would be discarded after a meeting, so I recommend something like Rock Oil Synthesis injector mix at 3% and the bike will hardly smoke whilst riding.
Thats a good point. I was running pro2 and £17.25 a ltr
Changed to motul fully synth for £12 ltr and it seemed thinner.
Posted: Sun Sep 22, 2013 7:44 pm
by camel
been thinking on them lines wack
it does seem to get better once its been in the tank a while,and the" garage forecourt jig "dosnt seem to mix it initially.
Posted: Fri Sep 27, 2013 6:27 pm
by soulboy
