Page 1 of 2
Air Fuel Ratio Meter
Posted: Thu Sep 19, 2013 8:32 pm
by TED CRUD
Just bought this bad boy to keep my engine in check when its built ,Discuss...........
Re: Air Fuel Ratio Meter
Posted: Thu Sep 19, 2013 9:19 pm
by Muppet
it comes with a sticker i want one,
muppet,
Posted: Sat Sep 21, 2013 1:58 pm
by TED CRUD
is anyone using one ?????
Muppet it is a nice sticker
Posted: Sat Sep 21, 2013 2:04 pm
by drunkmunkey6969
Ted......tell us a bit more about how you plan to install it and use it.
Posted: Sat Sep 21, 2013 3:49 pm
by CutdownSpence
More importantly were did you get it from ?
Posted: Sat Sep 21, 2013 3:58 pm
by drunkmunkey6969
CutdownSpence wrote:More importantly were did you get it from ?
Innovate Motorsport
Posted: Sat Sep 21, 2013 5:10 pm
by Stampede
I used the same tool to set up my carb on my Monza engine this year. Highly reconommend, you can adjust your carb in one day.
Posted: Sun Sep 22, 2013 12:14 am
by john.t5
How much and how good? Was actually wondering if something like this was available, it would be great for us over in NI where there is no one with scooter experience with a dyno.
Posted: Sun Sep 22, 2013 1:23 am
by CANbus
Yes TED Crud I have one but not installed it has yet.
I plan to weld on the socket to the exhaust next time I need to strip the exhaust down.
For me my plan is to run it periodically to check the engine is still within dyno settings.
I also note that the same company has a wifi version that logs to a apple app,
It looks a great bit of kit.
Posted: Sun Sep 22, 2013 7:31 am
by drunkmunkey6969
The lamba sensor looks to be the same one I have on my Dyno......a Bosch 5 wire sensor, same as used on AudiTT and such like. However mine is hard wired into the Dyno so it runs through a big box of electronics to convert the signal, which then runs through a PC, and finally the Dyno software. It's is all synchronised with the Dyno rollers and software so that I have a real time readout for the relevant throttle positions and RPM ranges throughout the rev range.......thus I can analyse an air/fuel graph at the end of the run and use the info to adjust accordingly. So the sensor is great......but one of many items which make up a complete picture (sensor, hardware, software, Dyno rollers, PC, throttle position, RPM range, Dyno curve). All I can see in the pic (via my phone) is the sensor, and a CD........? How will you rig this up it get effective info? And will it be a permanent fixture or detachable? Have you a link to the page you purchases from so I can read the spec? Cheers.
