Vapor trailtech
faf
Main scooter: GP 230 Mugello
Hi all,
Just fitted a vapor and wrapped the RPM wire round HT lead,but this doesn't seem to work very well! I believe you can wire direct to the Coil/CDI but do you connect to the LT wire or the pick up wire?
Cheers
Andy W
Main scooter: GP 186 Imola
Hi
I have a Trail Tech fitted to my Imola powered GP and it works perfectly fine and been fitted for 3 years. Have you got it wound round about 10 times? I have also put some insulation tape round to hold it in place.
Not sure which wire you would connect into on the CDI as I haven't needed too.
Andy
Trojan
Main scooter: LAMBRETTA INNOCENTI
Any idea as to what model it was ???? as I am looking to get one but seeing as there is so many different types just need to make sure I ve got the right one cheers
faf
Doesnt seem to matter how many times i wrap round the HT lead,it jumps about all over the place! have tried all 3 PPR settings aswell. Have also tried it direct to CDI now but still no joy :x
Dont know the model no: but got it from MBD
Tom Russell
Maybe, if you're not using one already, a resistor R type spark plug and cap might help.
Also, as with my digital rev counter, it's usually important to keep the RPM pick up wire, that you've wrapped around HT lead, away from any other wires and loom, right back up to the main unit.
faf
[quote="Tom Russell"]Maybe, if you're not using one already, a resistor R type spark plug and cap might help.
Cheers Tom will give that a try!
    Users browsing this forum: Google [Bot], Google Adsense [Bot] and 1 guest
