flywheel cover
oggy
Me thinking of a custom cover on my flywheel cowling,gona use spacers to stand proud of the standard cowling,will it alter the cooling?,it stands about 15mm proud of the std cowling,thanks
Minority
Main scooter: Li230 S3
For the lambretta cooling fan to work properly the fins must run as close to the flywheel cowling as possible (without touching :lol: ). People with far more knowledge than I suggest this is critical.
If your custum cover is fitted to the original cover, I guess all you would have to do is make sure there is at least as much air flow (holes/slots) as the original.
oggy
Cheers.
