carb needles...........and the common prob of weak mixtures
Posted: Tue May 12, 2009 9:22 pm
carb needles and the common prob of weakness at approx 5000 revs or so..........
it can be seen on a lot of dyno graphs etc..........on many two strokes.........
and occurs roughly at the point where the torque curve should cross the bhp curve.........
sometimes a bit earlier..................
much of this is explained away often by saying that its just natural........and is just what happens as a pipe comes "on song"........
to a certain degree this may be inevitable..........but then again there are things that could be done to at least lessen this,if not actually totally cure it..........
And............just to back track slightly.........in order to explain this a bit more.......
this common dip/flat spot/lean area.......isnt often much of a prob when accelerating and putting the power on..........because its in and out of it so quickly........and back into the safe range.............
where it is a prob.......is when someone is just cruising along..........and is in this range for a while...........
which goes some way to explain why most seizes/faults can occur ,usually at about only 50mph............
and so......back to needles......
most of these that are massed produced for most common carbs are simply a matter of tapers and straight bits.......
but what would be usefull maybe in order to correct the mid range lean spot would be a slightly concave shape on the needle............
this was suggested to me years ago.........by a well known racer..........
that in order to get a smooth mixture it was nessesary to hand finish and modify needles......................in this way..........
i have tried it a couple of times before............with quite good "seat in the pants "results.............
but it is very labour intensive............
i,d be very interested to see what anyone else thinks about this...........
also i appreciate the fact that Mikunis for eg are not as adaptable as delortos in regards mid range......tuning..........
and also that different pipes demand vastly different mixtures at certain revs........
