Page 1 of 3
Any ideas...
Posted: Sun Sep 08, 2013 10:00 pm
by Jxmiddle
Any ideas what would cause this? (Excuse the poor focus).
http://www.flickr.com/photos/91303085@N ... /lightbox/
The short rubber "mud flap" appears to have melted. I noticed the dark marking the other day and assumed it was some kind of grease but after a run up to London and back (35 miles each way) it ctualyy seems to have actualy melted. I've had some work done recently on the engine - new cank, seals, new 30mm carb - and it seems to be running hotter (cowling too hot to touch) but surely not this hot! Thoughts?
Re: Any ideas...
Posted: Sun Sep 08, 2013 10:08 pm
by lambro
I would say, after reading all about the rebuild and seals you have done.
My main concern is the new 30mm carb, I think this is where the problem stem from :shock:
In my experience and opinion, I think you have creased the mudflap up and inwards, by lifting the scooter by the rear end, or just backing into something and folded the flap up and in on the tyre.
Then the new found power from the 30mm carb has seen the flap subjected to extreme speed and heat whilst rubbing on the tread before becoming supple and falling down again.
IMHO.
:lol:
Re: Any ideas...
Posted: Sun Sep 08, 2013 10:10 pm
by Muppet
Alien abduction
Re: Any ideas...
Posted: Sun Sep 08, 2013 10:56 pm
by RICSPEED
yeah its got tucked up against the tyre and rubbed away
Re: Any ideas...
Posted: Sun Sep 08, 2013 10:58 pm
by Mark ULC
Did you park outside that walkie talkie building?
Was the flap on before the engine rebuild? Something nasty spill onto the flap maybe.
Re: Any ideas...
Posted: Sun Sep 08, 2013 11:21 pm
by drunkmunkey6969
Did you fit a fluffer-valve during the rebuild? This can sometimes lead to rubber-turbulence on the nearside deflector shield.......hence the mudflap deterioration. Try fitting an antimatter stabiliser to rectify this.
Or just remove the mudflap.
Re: Any ideas...
Posted: Sun Sep 08, 2013 11:32 pm
by rosscla
Too many pies?
Re: Any ideas...
Posted: Mon Sep 09, 2013 12:02 am
by Muttley McLadd
Could it be an electrical problem?
Re: Any ideas...
Posted: Mon Sep 09, 2013 1:22 pm
by Muppet
Muttley McLadd wrote:Could it be an electrical problem?
no way; my moneys on fuel from supermarkets; morrisons or adsa,
Re: Any ideas...
Posted: Mon Sep 09, 2013 2:11 pm
by skidmark
Had the very same thing happen to both mine and my mates GP's on the way to the eurolambretta this year, it was baking hot so guess the flap got very hot and more flexible than usual and got sucked into the tyre... strange eh!
