Can it run ok
Posted: Sat Sep 07, 2013 10:01 am
by Bifter
Can a scoot run fine but the timing be out ? just wondering as my 210 seems a bit sluggish lately ,i rebuilt it the other week with new seals and bearings and i am sure i put the timing back in the right place
Re: Can it run ok
Posted: Mon Sep 09, 2013 2:27 pm
by jonny snatchsniffer
if its too retarded yes
Re: Can it run ok
Posted: Tue Sep 10, 2013 4:57 pm
by Bifter
Any idea what a malossi 210 should be set at ?
Re: Can it run ok
Posted: Tue Sep 10, 2013 7:31 pm
by lambro
jonny snatchsniffer wrote:if its too retarded yes
The rider or scooter
Re: Can it run ok
Posted: Tue Sep 10, 2013 9:39 pm
by MCH
18 degrees is the standard malossi timing i think,
but as with every scoot, its best to get it strobed so you know the timing is spot on
Re: Can it run ok
Posted: Wed Sep 11, 2013 3:51 pm
by Bifter
lambro wrote:jonny snatchsniffer wrote:if its too retarded yes
Thanks Shaun
but in answer to your question probably both
Re: Can it run ok
Posted: Thu Sep 19, 2013 9:08 pm
you may have put weight on, i found my smallie get progressively slower cos of this
Re: Can it run ok
Posted: Sat Sep 21, 2013 9:58 am
by Bifter
If anything Jonny i have lost a bit of weight ,weird thing is every now and then it will perform like expected and go right off the clock
