tips on fitting endplate
Posted: Wed Sep 04, 2013 2:07 pm
by brianc
hi,got a new gearbox,the gear cluster is a very tight fit into the endplate bearing,when trying to tap the endplate on its going on at an angle and destroying the layshaft roller bearing,was thinking about freezing the cluster to ease fitting it over the bearing and cutting down an old spider and using as a puller,any tips/info welcome,
brian.
Re: tips on fitting endplate
Posted: Wed Sep 04, 2013 10:12 pm
by wack 63
Polish the cluster with emery paper just enough to push it in the bearing. A lathe is best or a large pillar drill to hold it.
Posted: Wed Sep 04, 2013 11:30 pm
by Elite-225
Fine emery maybe..shoudn't have to really ffs ! :|..tap tap ..pull pull,,take your time .. don't force
Posted: Thu Sep 05, 2013 5:44 pm
by brianc
made up a dummy bearing holder and put it in the vice then spun the cluster by hand and used a very fine file,took very little off, sorted.
brian.
