convert 4 plate sprocket to 5 plate
mickdale
can you convert a 4 plate sprocket to 5 plate?
will it take 5 surflex b's?
cheers
mick
Yes but you will need thinner steels and to get it to work properly you will need to mix and match them to make sure that you have the correct clearance between the plates when full compressed (1.5mm). Good springs like those from MB are a help to. I have a couple of standard friction discs in mine to get the clearance.
stokky
Pete Merchant (Rochdale Solely Scooters), has some specially hardened 1mm steels
not cheap, but at least won't warp.
Oh and to be honest I got some, and they are a tad too large for basket, so needed a little filing to fit
stokky wrote:Pete Merchant (Rochdale Solely Scooters), has some specially hardened 1mm steels
Mine came from Camlam, cheep as chips and haven't caused any problems in my Avanti 225...wouldn't suit an RB or fast TS1 though.
10 inch Terror
Xbox live gamer tag: No.
I'm using the Readspeed 5 plate kit which is designed as a straight fit into standard baskets and components. It's spot on in my 20BHP Imola which no slip or drag. I'd suggest you go with those for under £50 you can't go wrong...
mickdale
Thanks ten inch
    Users browsing this forum: Amazon [Bot], Google [Bot] and 5 guests
