Wireing help
Posted: Wed Aug 14, 2013 9:54 pm
When I swapped out my front brake lever I just pulled off the wires that were on the front brake switch.
My brake light worked fine before I did this and Iv`e drawn up a diagram of how the wireing is.
Can someone explain what I need to do to get it to work again?
I had to Ohm the loom because the wireing goes through the frame, so there isn`t any faults.
It`s on a variatronic, if that means something. It doesn`t look like the way i would normally do it.
