BGM 120w stator,which regulator?
Posted: Fri Aug 09, 2013 7:44 pm
by speedy
Eh up folks just a quickie.Now that BGM only make one stator,the 120w version,what regulator should be used?Is the Ducati one which I think is 80w good enough,or is there something out there that is designed for the job.Just concerned that the extra 50w may discharge itself somewhere like me frame or somewhere else horrible.Cheers,Speedy.
Re: BGM 120w stator,which regulator?
Posted: Fri Aug 09, 2013 7:47 pm
by servetakid
Ive used both the Ducati and the BGM one without issue
Posted: Fri Aug 09, 2013 8:01 pm
by coaster
I don't think BGM call it a 120 Watt stator anymore, they never did produce 120 watts anyway....or you could convert to DC and use the Wassel 120 watt regulator/rectifier.
Posted: Sat Aug 10, 2013 11:30 am
by speedy
Thanks folks! I've never used the BGM before as i'd always had the AF Ducati ones and of late the Indian built AF ones I've had the issues with.Just wanted to make sure all was correct before fitment as to create any issues.Cheers,Speedy
