Page 1 of 2
Early Imola cylinder head.
Posted: Thu Aug 08, 2013 6:39 pm
by 10 inch Terror
Hi guys, does anyone know where I can get an early kit cylinder Imola head? It's the type with the side squish and 4 stud holes. I've tried Cam Lam and Mike Phoenix but they are out of stock until September. Thanks in advance Pete.
Re: Early Imola cylinder head.
Posted: Thu Aug 08, 2013 7:37 pm
by Donnie
You have asked for the right one i assume, and I assume its for the one you had a thread about earlier in the week? ie the head with the collets, you don't want a mk 1 head if so, you need to specify the collet version
Posted: Thu Aug 08, 2013 10:48 pm
by 10 inch Terror
Donnie wrote:You have asked for the right one i assume, and I assume its for the one you had a thread about earlier in the week? ie the head with the collets, you don't want a mk 1 head if so, you need to specify the collet version
Yes mate, I spoke to them both on the phone and neither had any in stock. I've cleaned up my head now and I think it will be ok to re-use it. Thanks for your time Pete.
Posted: Fri Aug 09, 2013 10:54 am
by Donnie
thought you said there's a bit missing off it?
Posted: Fri Aug 09, 2013 11:55 am
by 10 inch Terror
Donnie wrote:thought you said there's a bit missing off it?
I've spoken to a grown up and they said its ok to use again. It just needs skimming slightly.
Posted: Fri Aug 09, 2013 5:48 pm
by Donnie
OK, just make sure the surfaces are mated properly and you check how the skimming affects your squish mate.
Posted: Sat Aug 10, 2013 8:59 am
by 10 inch Terror
Donnie wrote:OK, just make sure the surfaces are mated properly and you check how the skimming affects your squish mate.
The squish was set at 1.3mm so if I take 0.1mm off that should then give me 1.2mm? Which I believe should be ok. Thanks for your comments much appreciated.
Posted: Sat Aug 10, 2013 12:02 pm
by Donnie
Don't assume it'll give you 1.2mm, definitely check it when fitted.
Posted: Sat Aug 10, 2013 2:51 pm
by 10 inch Terror
Donnie wrote:Don't assume it'll give you 1.2mm, definitely check it when fitted.
Yes I'll make sure. What method do you use for mating the surfaces? I'm thinking of using a mirror with some 800 wet and dry taped to it and slowly lap it on that. Is that a good or bad idea? I'd rather know now before I try it. Cheers Pete.
Posted: Sun Aug 11, 2013 8:20 am
by Donnie
Yep a mirror or any properly flat surface will do the job.
