Wiring help
Posted: Sun Aug 04, 2013 11:26 pm
by Bagpuss
Hi I have a vespa T5 classic. Non battery type. I'm trying to fit a battery to it. I have obtained a battery tray, battery and battery strap. I've now got a 5 pin regulator. I'm unsure how to wire these up. I'm using the battery to power a car stereo and a power socket to charge my phone. Any help would be appreciative
Re: Wiring help
Posted: Mon Aug 05, 2013 12:05 am
by coaster
The 5 pin regulator connects up exactly the same as your existing one, you then need to take a wire from the B+ terminal on the new regulator to the positive side of the battery and a wire from the negative terminal of the battery to a good earth on the frame. Put a fuse holder in either the positive or negative leads to the battery.
Re: Wiring help
Posted: Mon Aug 05, 2013 1:31 pm
by Bagpuss
Thanks coaster. Then do I just take a lead from the positive side of the battery to the stereo with an in line fuse on that wire and then earth the stereo?
Re: Wiring help
Posted: Mon Aug 05, 2013 1:37 pm
by Bagpuss
Ps where abouts are you from in Norfolk?
Re: Wiring help
Posted: Mon Aug 05, 2013 1:53 pm
by coaster
Yes, that will get your sterio working but I'd think about havering a hidden
Hidden switch if it needs to isolated when unattended.
Garboldisham near Diss
Re: Wiring help
Posted: Mon Aug 05, 2013 2:08 pm
by Bagpuss
Yes was gonna do that. You must know Kevin seaman, and Andy slim Davies then? I'm from Norwich, I'm a Norwich broadsmen member
Re: Wiring help
Posted: Mon Aug 05, 2013 3:36 pm
by coaster
Bagpuss wrote:Yes was gonna do that. You must know Kevin seaman, and Andy slim Davies then? I'm from Norwich, I'm a Norwich broadsmen member
Don't kow any local lads by Name although have bumped into a few. I do know several of the Norwich boys though, peach, Jarv, Tidd, Broady, Jim, Olly to name a few
Re: Wiring help
Posted: Mon Aug 05, 2013 6:20 pm
by wack 63
If you are good with wiring you could change your ignition switch under the horn stem to an electric start one with 4 wires so your auxiliaries work off the key.
