mb RT 190 carb set up.
Posted: Sun Aug 04, 2013 10:37 pm
Hi
I recently had the above kit fitted but I'm not to clued up on setting the carb.
I have trawled the web to find someone who has the RT 190 set up and running how it should. but with no success.
I have a 28mm phbh nk rally and mb remote filter.
Idle 58
Main 125
X7 needle second notch down
40 slide
Mix screw 1 1/2 turns out roughly.
It starts to splutter just as the power starts to come in
And on Sunday at the Humber bridge YSA event as I was going up the the steep slip roads I had to feather the clutch and give extra revs to stop it spluttering on the steep slip roads.
As said earlier I have trawled the web but only found threads on people with roughly the same problem as me.
So if any one has a similar set up. Id love to hear from you.
Thanks from a very frustrated Boris.
Idle 58
Main 125
40 slide
