Engine diagnostics please.
Posted: Sat Aug 03, 2013 12:45 am
First semi long ride on RB22 and I have a problem.
Firstly it is 4-stroking at 1/4 throttle,
Secondly after riding hard(ish), the engine revs "itself" when the clutch is pulled in.
I suspect either an air leak or jetting prob.
There is no sign of any gaskets leaking, scooter is clean as a whistle (maybe too clean ie. no fuel on the floorboard)
Oil is fine, no petrol in there and the correct amount.
I stripped the carb and found that the previous ownder has botched the choke and it doesn`t seat when turned off.
This means that the choke is on at all times.
I was thinking that the 4-stroking at 1/4 throttle could be slide related, so had that out too.
Plug is a NGK R CR8E and looks ok but I think it should be pretty black considering the choke is on.
Setup;
Standard RB22, Fat mamba, mb crank.
Mikuni 35 Jets;
Needle 6EN11-47 2nd clip from top
Main 310
The weird one is pilot jet. All I manage to read on that is 02??
Carb is unfiltered.
Where should I start? and how to I test the flywheel side seal?
Setup;
Mikuni 35 Jets;
Main 310
Carb is unfiltered.
