gaskets
Posted: Fri Aug 02, 2013 7:00 am
by LI150
I am always having issues of leaking carb manifold gaskets. What's best ones to use? Its a 28mm carb on a 210 malossi
cheers Tim
Re: gaskets
Posted: Fri Aug 02, 2013 8:34 am
by Darrell Taylor
check both faces with a straight edge as there normally in need of facing off/lapping which causes uneven tightening onto the gasket, then use a gasket and sealant (loctite 5910 good)
Re: gaskets
Posted: Fri Aug 02, 2013 10:02 am
by LI150
Cheers Darrell
