Page 1 of 2
BGM Stator/Flywheel Poll
Posted: Mon May 11, 2009 10:25 am
by RinB
Please Vote on your combination of BGM Stator & Flywheel that seem to work
Also please post any mods you have had to do to get it working
Thanks
Smiffy
Re: BGM Stator/Flywheel Poll
Posted: Mon May 11, 2009 1:28 pm
by Dimitrios_231
BGM 120W stator with GP Elemec flywheel,no problems at fitting but can't get the timing less than 22.Apart from that, it works fine.
BGM 120W with new AF lightened,doesn't work :( .
I'm waiting to try the MB lightened (2Kg),this week.
Posted: Mon May 11, 2009 1:43 pm
by RinB
Dimitrios_231 wrote:BGM 120W stator with GP Elemec flywheel,no problems at fitting but can't get the timing less than 22.Apart from that, it works fine.
Good feedback m8
Im sure the MB one will work
Posted: Mon May 11, 2009 6:16 pm
by corrado
I've just fitted this combo, no fitting issues but not tested it yet as other things, not allied to ignition, still need doing before it's a runner.
Posted: Mon May 11, 2009 6:22 pm
by Dimitrios_231
Couldn't get a steady tickover.
Couldn't keep the revs.
A strange sound was coming from the maghouse.
I was told that the new ones in combination with the GP mec crank that I have,didn't need any mods.Not in my case.
Posted: Mon May 11, 2009 7:28 pm
by al-super3
I am running bgm 120 with standard sil flywheel.
I swoped from a sil stator that was in there for 6 years with no problems in serch of more power (electric) but is no better
When is some one going to do a 120 wat regulator to match
Timing wise no problems
Cheers Al
Posted: Mon May 11, 2009 9:07 pm
by teamsequipe
BGM 120 using a standard Ducati Italian Electronic flywheel, no issues.
Posted: Tue May 12, 2009 5:07 pm
by Ihateyoubutler
Bgm 120 with a jb lightened sil flywheel (plastic fan).Timed up no problem at 19 degrees.Seems to be enought stator adjustment left to fit augusto when a I've few more miles on the engine.
Posted: Tue May 12, 2009 9:27 pm
by Jonny G
Af Lightened Flywheel, BGM 120W Stator and an MEC Crank. 1mm machined from the mag housing face. 300 miles with no probs whatsoever !!
Posted: Wed May 13, 2009 3:23 pm
by RinB
Any more voters
Another question are the AFR light flywheels old or new type ie new have a packer in between
boss & flywheel.
Also 120w BGM old or new ie new ie pickup is no located futher in Ie laminates taken off
from manufacture.
