Fancy Rod and Jap Piston
Posted: Tue Jul 30, 2013 8:56 pm
Hello
Will shortly start building a motor for my GP on 200 casings. I fancy an old school Jap piston conversion using one of the two barrels I have in my shed. Crank wise I'm keen on an Indian GP crank with a Vespa Ape rod conversion or a Yamaha rod, depending on the piston I end up using.
Pipe will be a JL3 and a 30mm PHBH carb will be on the induction side of things. I can get a bit of barrel skimming and piston chopping done at work, but tuning wise I'd like something like a stage 5 which I'd get done by a man who can.
Looking at the old MB site it looks like my options are:
Using an Ape rod with 18mm gudgeon pin diameter - Suzuki PE250 piston to give 205cc; Suzuki TS250 piston to give 225cc or a Polaris 750 piston to give 220cc.
Using a Yam rod 115 long - Kawasaki 440 jet ski piston to give 210cc.
Anyone got any experience of any of the above - either pistons and / or cranks - at all please?
Any advice, yarps, narps and gentle abuse welcome.
Any local crank building contacts and tooning contacts welcome too. I live in North Brum.
cheers
cheers
