gaskets
LI150
Main scooter: Series 2 LI150
I am always having issues of leaking carb manifold gaskets. What's best ones to use? Its a 28mm carb on a 210 malossi
cheers Tim
Darrell Taylor
Main scooter: LAMBRETTA
check both faces with a straight edge as there normally in need of facing off/lapping which causes uneven tightening onto the gasket, then use a gasket and sealant (loctite 5910 good)
LI150
Cheers Darrell
