lambretta springs
frankie
Who is the best dealer to get progresive fork springs from for my GP.
Ive had some from Af and Mb and they are no good scoot is bottoming out when i pull the front brake.
I think Scootopia have started making their own progressive springs now. British made and might be worth a look.
frankie wrote:Who is the best dealer to get progresive fork springs from for my GP.
do you have dampers fitted ?
dapper
My first thought too Steve :shock:
frankie
Yes BGM dampers fitted
What brake are you using? Outboard hydraulic disc with Nissin (or similar) calliper?
joespeed
soulsurfer wrote:What brake are you using? Outboard hydraulic disc with Nissin (or similar) calliper?
i think you may need an anti dive set up not new springs!
frankie
Using outboard hydraulic with nissin calliper
Muppet
Add more pre load to y springs
C’est la vie
frankie wrote:Using outboard hydraulic with nissin calliper
Therein lies your problem! These calipers are from a Honda motorcycle with more speed and larger wheel, they're just too much for a 10 inch wheel. Your options are either to change you brake or fit anti dive, don't throw any more money at springs and dampers, you already have the best [WINKING FACE]
    Users browsing this forum: Ahrefs [Bot] and 7 guests
