drive side oil seal???
Posted: Sat Jul 13, 2013 1:32 pm
i have fitted a af rayspeed stage 4 175 kit to my gp 150,
jl2 pipe
running it with a 26mm phbh -
x7 needle 2nd clip down
50 pilot
108 main
40 slide
iv got a spark,
today i tried a new spark plug, still it wouldnt start, i pulled the spark plug out and it was oily black, then some white vapour started coming out the plug hole
looked in stickys manual and it just sounds like drive side oil seal,
previous to putting the kit on it never ran right, never kept at idle, had to keep revving it and when i started it up it did have quite a bit of white smoke but then it faded as you rode it, but still it would sometimes cut out or cut out if the revs dropped,
so could it be i have mixed the wrong amount of two stroke in or could it be drive side oil seal?
going to try some fresh fuel with new correct mixture or should i just change the seal anyway?
jl2 pipe
50 pilot
108 main
40 slide
iv got a spark,
