Racing
Posted: Tue Jul 09, 2013 5:16 pm
by Bifter
Got home from work and as i pulled up to the garage and put the scoot in neutral it just started racing ,put it back in gear with clutch in and revs return to normal :?
Any ideas ?
Re: Racing
Posted: Tue Jul 09, 2013 10:30 pm
by Wayne Miller
Air leak
Re: Racing
Posted: Tue Jul 09, 2013 10:58 pm
by goldeneye
flyside oil seal. pulling the clutch in is pressing the crank against the worn seal, sealing it up again. easy fix, flywheel off, stator off(mark position for timing etc.) prise old seal out, squeeze new seal into position.replace bits in reverse order etc.
Re: Racing
Posted: Wed Jul 10, 2013 4:05 pm
by Bifter
That's both sides then :roll: already going to replace it as my crank oil seal has gone as well ,did wonder why the engine was covered in a black dust .Just glad its not something else .
thanks for the replies guys
Re: Racing
Posted: Wed Jul 10, 2013 6:04 pm
by goldeneye
if you are doing both, you might as well do the crank bearings while you"re on with it.....and the cruciform, and piston rings, gaskets, clutch plates and springs.......
Re: Racing
Posted: Wed Jul 10, 2013 6:31 pm
by Bifter
I have a full set of bearings and a cruciform and all seals on order
