http://www.mitolambretta.com/product_in ... cts_id=236
Discuss
Mito racing oil seal conversion
- Speed Demon
- Dealer
- Contact:
I don't think they are first to be doing a single seal conversion - I believe it is recommended on the Super Monza engines.
Get to SULK
Does that version have a groove in the mag housing
- Speed Demon
- Dealer
- Contact:
Never seen it yet, but yes I believe that it does have an oil feed.
Get to SULK
- registered user
- Main scooter: Series 1 li150 1958
- Contact:
1950's S1 technology
this will reduce crankcase compression surely?, the mix having to fill the bearing area as well .
I thought larger crankcase volume was a good thing?a.lo.v2 wrote:this will reduce crankcase compression surely?, the mix having to fill the bearing area as well .
cheers
mick
Yes it is and it does have the oil feed in the mag housing too.Speed Demon wrote:I don't think they are first to be doing a single seal conversion - I believe it is recommended on the Super Monza engines.
But is it any good /worth doing ?
