Page 1 of 2
gearbox problem
Posted: Wed Jul 03, 2013 5:52 am
by lammydave
My Sx gearbox is starting to annoy me..... the gear cluster mullered the bearing in the casing, so I had to strip the whole thing down and clean all the bits out....
When I put it back together the loose gears and cluster will mesh nicely and spin freely....
But as soon as I fit the endplate, even loosely, a tight spot is apparent... And when the plate is fully tightened, it's worse..
New bearings all around, shims in right place, under gear cluster etc... Even does it with a different endplate, but with no bearing in the backplate, it all spins merrily... Now I'm no expert on gearboxes, so wassup?
Re: gearbox problem
Posted: Wed Jul 03, 2013 6:32 am
by WINTERMODEL150
Put the rear hub on and torque up correctly. .if it still locks up it's possible that you need to re shim first gear..also make sure the crown wheel and spider are fitted and the centre nut is tight .
Dean
Re: gearbox problem
Posted: Wed Jul 03, 2013 6:40 am
by lammydave
thanks, dean...
did the hub up, problem still there, it all worked fine before, although I do know that the endplate is not original to the scooter...
Re: gearbox problem
Posted: Wed Jul 03, 2013 7:29 am
by WINTERMODEL150
New rear axle bearing? If so then this could give you a different first gear shim tolerance
Re: gearbox problem
Posted: Wed Jul 03, 2013 7:30 am
by WINTERMODEL150
Build it up without the first gear shim in and see if it spins freely
Re: gearbox problem
Posted: Wed Jul 03, 2013 7:33 am
by lammydave
i'll give that a try, Dean.. thanks
Re: gearbox problem
Posted: Wed Jul 03, 2013 9:02 am
by tonydevon
when you say a tight spot, do you mean it turns and then goes tight, then loose again
if so then surely something is either bent, or a gear isnt sitting central?
Re: gearbox problem
Posted: Wed Jul 03, 2013 10:10 am
by lammydave
tony
yes, that's exactly what I mean.....
thought it strange that the gear cluster mullered the bearing in the housing... so maybe that's the issue..
also, on closer inspection, one of the gear teeth is chipped... :-(
Re: gearbox problem
Posted: Wed Jul 03, 2013 10:18 am
by Adam_Winstone
Did you do this bit too...
"..also make sure the crown wheel and spider are fitted and the centre nut is tight ."
Re: gearbox problem
Posted: Wed Jul 03, 2013 9:49 pm
by Yanker
Original box with original end-plate, or 'not known' ?
You have the right cluster and loose to mesh....deffo?
Italian?
What was the alighnmet mumber in the two endplates used?
